1 - 19 of 19 Posts
Without machine work, and NA what is the horsepower I can expect? What head should be used?
w/ my magic bag
Yrs ago Tri-Point engineering had a few 25's in 3's....270hp w/ 220lbs of grunt.
I’m researching as much as I can get in but with the knowledge on this forum sometimes I prefer to ask directly.
Discussion Starter #10
The build is only for fun. Budget is $5000 for the motor. But there’s some wiggle room if it goes over a bit. From what I read I can use the internals from the 2.5, upgrade the cams, use a different head or get machine work etc. where I’m having difficulty is to go turbo or stay NA.
Discussion Starter #14
Through my reading i understand run the 2.5 head and get machine work done. High compression pistons. What about individual throttle inlets?
1 - 19 of 19 Posts
