1 - 20 of 47 Posts
so my car vibrates like a massage chair. its really really intense and i feel like the entire car is going to shake to peices. i have a cfm's "race" dogbone mount and i think that is my problem. this is my first winter on the mount and i think when it gets too cold it just gets stiffer.
anyone else experiece this?
any thoughts?
Thanks,
Oliver
Ive heard the vibrations with the aftermarket mounts can be pretty strong.
FF PHOTOG ENTHUSIAST
once it warms up ... it feels better. Its going to vibrate ... If you are still on your stock tune it will vibrate on a cold start. A WHOLE LOT. down the road look in to a Tune and it will tone the shaking down ... but you will still get it.
NOW if you are shaking while driving there are more factors in play than your dogbone mount.
Discussion Starter · #5 ·
figure out whats wrong in this picture
Discussion Starter · #6 · (Edited)
my engine fell out... literally
:[ im sad
Obama Can't Gymkhana
^^That is a problem. HA.... I didnt think it was the rear mount. It wouldnt shack that Much.
i wear no pants
lol hardcore pwned.
Before you fix that you should lend it to your Gf to see how strong the vibrations really are
Discussion Starter · #13 ·
amazon.com had some good deals on other things that vibrate recently so i got that department under control. hahahahahahappahpahapahahah
but i have no idea what im going to do[:(]
well, is it only wile moving, or at an idle too, does it vibrate more as the rpm goes up, hows it running, we need a little more info but i would start by looking at all your pulleys, make sure they aren't broken. swap out that dogbone with the stock one, see if that does it. if not, make sure you don't have any codes. may be check the plugs and wires too.
give us some more info so we can point you in the right direction.
The Librarian
^^^Um...look at the picture that c9ollie posted.
I believe he found the problem. [;)]
And, c9ollie, I merged your other thread with this one and updated the title.
Please try to refrain from posting the same subject in two different areas.
Thanks.
^^^ was that the cause, or was that an outcome of the vibrations.
1 - 20 of 47 Posts
