It is a 2003 with a 2L Zetech engine.
I got it at 99K, it now has 116,800miles. It had a new clutch put in at 88k. It has body issues dents and such, but not a lot of rust.
I was driving down the highway at about 60mph and it started loosing power like bad gas/fuel issues. I stepped on the gas and it did not go like it should. A few miles down the road it started to rapidly slow down more so then coasting, as if a wheel bearing went out. I tried to take it out of 5th gear and it would not go out of gear. The shifter was stuck in place. After coming to a stop I was able to pry the gear out of 5th. But it did not want to go back into 1st 2nd 5th or reverse. I then tried to let my car idle but it acted like it wanted to go backwards. It is mostly frozen in place, if I rev it up and drop the clutch it will move forward in 1st but will stop after a tire turn or so. Same with reverse. The front wheels are locked even in neutral. If I press in the clutch, the motor runs fine but stalls as soon as I release the clutch in any gear. Car was making a small noise in neutral for a long time but the noise would go away when the clutch was pressed in. It also was sometimes difficult to slide it into 5 gear and 1st and 2nd gear for at least 10k miles. But not every time. Sometimes it would shift fine. I figured the linkages needed to be adjusted or something. The Tow truck driver offered $75 for scrap metal, but I have not yet sent the title. Should I be thinking of salvaging it??? At this point I think I HATE FORD for life. My Taurus auto v6 transmission went out at 184k and after a rebuild the transmission cooling lines went out at 220k and the lack of ATF killed the rebuild, it went to the junkyard for about $110, at this point I think it reflect poorly on Ford. Should I sell it for scrap, pay to store it and sell the parts, or try to fix it? It is a two hour tow to any family's place so the towing it could be costly. The shop near where it broke had a 4.9 star review, and told me they would fix it for $1000, but its only worth $1400 I think. I think I only paid $1100 for it and it only got me 17,000 miles so far. Is a MK1 clutch plate easy to fix if I have a puller? The front wheels might be locked so tow strapping it is a bad idea. At this point should I just be saving up for a nicer hatchback? (Maybe a Honda this time) Advise appreciated!
