1 - 2 of 2 Posts
Pulled transmission and have the mfactory lsd on it’s way, curious as to other things I need to install it and also best trans fluid to use with it as well. Also wanting to know torque specs on ring gear.
w/ my magic bag
I used the Ford fluid.....I also ordered the carrier bearings as well as the speed sensor at the same time. I had the trans hung on the end of a trans table of which I sucked all the old fluid out. I ended up using a tad bit over 2 qtrs. btw its also a great time to upgrade your front sway bar, as I regreased the Eibach front bar since it was squeaking some as I had the cradle on the floor.
1 - 2 of 2 Posts
