1 - 2 of 2 Posts
After removing the transaxle you will need to seperate the case halves. The input shaft should come out fairly easy after that. If you are just replacing the shaft you will have to press a couple of bearings off of the shaft and remove some gears and syncronizers, install them on the new shaft and reverse the process. The parts should be available from a ford dealership (and not likely available new from anywhere else.)
Why do you need to replace your input shaft?
1 - 2 of 2 Posts
