1 - 3 of 3 Posts
Today after running my car a little hard i used my predator and did a troubleshoot. When i pulled up my codes i had P1518. The code says intake manifold runner stuck open. It also says refer to p2004. I would appreciate the help on what exactly intake manifold runner stuck open means.
Discussion Starter #2
P1518 - Intake Manifold Runner Control Malfunction (Stuck Open) The IMRC system is monitored for failure during continuous, key ON engine OFF or key ON engine running self-test. The test fails when the signal on the monitor pin is less than an expected calibrated range at closed throttle. IMRC monitor signal circuit shorted to PWR GND or SIG RTN
Damaged IMRC actuator
Damaged PCM
An IMRCM PID reading approximately near 1 volt at closed throttle may indicate a fault
can someone break this down for me.
1 - 3 of 3 Posts
