1 - 3 of 3 Posts
bought the car knowing moonroof was partialy opened figured I could fix it.
I removed the four torx bolts and removed window, and can see drivers side track is way forward and jammed tight while passenger side is back and moves freely.
anyone dealt with this issue.thought I heard motor move a little but idk...
I would just like to line the track up and pop window back in...
does it need to be under power to seal window...
Discussion Starter · #2 ·
there are three tabs that slide under the window mount ,one side has the rear tab above and the other side has all three tabs below,anyone have a clue to which is correct,any ford mechanics out there??
[popcorn]
1 - 3 of 3 Posts
