1 - 14 of 14 Posts
I am having a problem with my 2013 Focus speed sensor. It will randomly display not supported on my odb2 computer. I have replaced the sensor and I still have the problem. The old sensor had a small bit of damage on it. How do these sensors work?
The car will randomly detect the problem and when it does it displays a service message and the car loses most of its power.
I do not have a abs computer, but I did bring it in once and they said front right speed sensor was giving error codes. Any idea what to try next?
Discussion Starter #2
Can someone tell me where the pickups are for the front sensor? Are they on the wheel bearing? I can't seem to find any information on this one and with snow on the ground I'm concerned the abs system wont work properly.
They are on the wheel bearing. The bearing has a magnetic strip that sends signal to the sensor itself. I know because I've busted apart the ENTIRE knuckle to fix an abs sensor issue
I brought it in to find what wheel was having the problem and the computer said it was a short or open in right front speed sensor. So to me it sounds like a wiring issue. This car was in a collision so it is possible that its cut somewhere.
I have the wiring schematics, but it shows the wires run into the ESP Module at plug C1CA01- 34 and C1CA01- 33. But where is the ESP module? I have never heard of that. Is that the same as the abs module?
I just tested continuity from speed sensor plug to esp plug and it tests out good. (ESP is the ABS pump)
So now I'm really lost. What are the odds that I had a bad speed sensor and for sent me another bad sensor? Its getting really dangerous to drive now too. Today the car wouldn't let us move more than 2mph from a stop light.
A bad sensor itself can report as an open or short circuit aswell. I know im not much help. But it is certainly not unheard of for things to be bad out of box
Discussion Starter #8 (Edited)
I agree with that, but the odds of the one in the car being bad with only 16,000 miles on it and a new one are very slim.
Okay so I need some help on this. The shops I took it to read that it has a short in the front right speed sensor.
So they said I should replace the speed sensor harness. I did and still get the message. Now I have decided to cut out and replace the entire wire feeding from the ABS module to the speed sensor. After doing that I get hill start not available and no speedometer functioning. Now I'm leaning towards a faulty abs module.
Does anyone have any tips for me on this? I have already spent over 30 hours trying to figure this problem out and have gotten nowhere.
Thanks
Edit: So I guess I didn't check for shorts well enough. I found I somehow had one somewhere under the heat shrink tubing. Now I have fixed that were back to a functioning car. I need some time now to test it out and see if I get the fault again.
Discussion Starter #9
The problem is still here. This is what I have done so far.
Replace Speed Sensor
Replace Wire from speed sensor to ABS pump
Replace ABS pump
Right now I am always getting hill start assist not available at all times. So I am going in reverse. I have no idea where to go now.
When you replace the ABS pump it NEEDS to be recalibrated to your car. I just went through this myself. Just take it to a dealer and tell them you need the ABS module reflashed. If they say they cant do it go to another dealer. I think these cars have issues with modules.
Discussion Starter #11
Did your car display any error codes before it was calibrated. I think mine might be something more. I looked in the shop manual and it didn't say anything about calibration after replacing.. I think I am going to take it to the repair shop now. I just have no more ideas on it.
Trust me, it needs to be recalibrated. Take it to the dealer. When I had my old module, it gave me codes saying the module was bad. Then I got the new module and the codes were that the lateral and longitudinal sensors were not calibrated.
  • Like
Reactions: schrodingersbox
Since the ABS was not calibrated, the PSCM was saying invalid data received.
Look up the codes in the manual and you will see what I mean. Once it was recalibrated, all the codes were nonexistent and the car is at 100%
1 - 14 of 14 Posts
