Okay so as you can see to the left I have the 201A appearance package 17x7 wheels. I want to widen the stance of the car for a better appearance and right now I don't want to shell out for new rims and tires. I will probably do that in a year or two but today it's not going to happen.
I am considering doing spacers though. I don't want something ridiculous and from what I've read on FF, doing anything bigger than 15mm is pretty risky anyway unless you swap the studs. That is a bit more work than I want to do. I also do not plan to lower the car any time soon though that is on the agenda for later (probably when I get new wheels and tires.)
So I want to pull the wheels off, slap some spacers on, tighten it up and be done.
I am looking for opinions here but please don't be a dink about it.
1) Is this even worth it? Would it even be a noticeable change in width?
2) If there is a noticeable width difference, at 15mm with stock wheels, tires and ride height would it look stupid?
3) If it doesn't look stupid would it be better to do the same width all around? wider at the rear narrow at the front? vice versa?
4) Would there really be strain on the bearings with such a small spacer? I know physics dictates there would be some strain since the bearing is behind the spacer and therefore taking more load but is it really that much considering the width of the spacer is less than 1/2"?
5) where on earth can I get spacers with a 5x108 bolt pattern that are 15mm or less?
Thanks in advance.
NOTE: if there are already threads that answer any of these questions please feel free to direct me to them.
Thanks in advance.
