1 - 6 of 6 Posts
2016 535D
I've posted a little on some of the other sub-forums about my car but I think its finally time for a build thread so that maybe I can provide to the community and answer some questions. First of all, my car is a 2012 SEL sedan in Race Red. It was obviously an automatic and I got it with about 25,000 miles on it. It has gone through a number of iterations and changes but I'll cover what it has today.
Suspension:
-Corkport Mazda3 coilovers and camber plates
-Steeda rear anti roll bar
-Whiteline lower control arm bushings
-DIY rear strut tower brace
Brakes:
-Volvo C70 front calipers and rotors
-StopTech street pads
-DOT 5.1 fluid
Engine:
-Toms Tune
-OBX header with 3" collector
-AEM Filter
-Custom full 3" exhaust
Transmission:
-MTX75 manual swap
-Team Mfactory LSD
-Steeda short throw shifter bracket
-Solid shifter bushings
-Solid shifter cable bushings
305656
305657
This setup is fun but having gotten into other cars I realize that it is very slow. Until you get into a big turbo ST or and RS, I would consider the MK3 focus to be very slow. This leads us onto the current project for this car: a built motor.
2016 535D
Discussion Starter #2
I had been wanting to build a motor for this car ever since I started browsing the Esslinger catalog for duratecs. I am still in the parts procurement process for this but I think I'm getting close enough to give an update on where things are.
305658
The components you see are all forged. The crank is for a 2009+ NC miata and was keyed by MassiveSpeedSystems. The rods are Manley H-beam and also for an NC miata. Finally, the pistons are Esslinger's custom design for the 2.0 Ti-VCT engine, made by JE pistons. Not pictured is the ARP main studs, Crower valve springs, and other goodies I have for this engine. As for the power adder to make use of all this, I'm going to do something a little controversial initially...
305659
Thanks for sharing! Can't wait to see how much you horsepower you can get out of the little engine. Are you planning on staying NA?
2016 535D
Take a good look at that last picture again. By "NA" do you mean "nitrous assisted"? That's a direct port wet kit capable of about a 250 shot with the biggest jets. Also, I should have mentioned this before but the pistons are 10.5:1 compression; not exactly ideal for big naturally aspirated power.
I wish!😏 Honestly, I'm not very familiar with nitrous. Very curious as to how much power you'll be making though.
1 - 6 of 6 Posts
