Is there a way to performance tune using my modified elm 327?
Disconnecting ABS wheel sensors would do the trick[grinking]For the S model guys, is there a way to turn of traction control with the tuner?
But you don't need that right...?Anti-lock brake systems. Traction control. Electronic stability control. None of them could exist without wheel speed sensors. Even variable assist power steering rely in part on information from the wheel speed sensors.
Maybe an IPC swap can work (that has the menu to disable TC)I live in Michigan and get tons of snow in the winter. I'd really like to be able to just turn off my traction control without compromising the other features...
+1 Give the man some rep points, never fails to help anyone! [hihi]I'm telling you, man, you're a walking focus encyclopedia lol!
When no one else has the answer you've got it!
Thank you!
If TC could be turned off with a switch instead of having to go into menus...nice!OK Bud, here ya go:
http://www.focusfanatics.com/forum/...actory-cruise.html?highlight=traction+control
Not all that hard, you can gain T/C off and cruise control.
