sweet, thanks for the quick reply.
i dont know if you are well versed in suspension but what are you thoughts on the rear toe links? i'm just seeing all of this stuff on Steeda and dont really know if it's worth it or not.
I'm pretty well-versed on suspension. I had upgraded pretty much every part of the suspension on my Mustang. The only thing you would get from toe links is more adjustability which isn't really needed unless you're making some pretty serious changes in your suspension.
Sway bars will prevent your car body from rolling when making a corner. It will keep the body more firmly planted with the surface you're driving on.
I would start out with a rear sway bar, then maybe move onto some springs and struts/shocks. The sway bar will have much less effect on daily driveability whereas upgraded springs and especially struts/shocks will make your ride much rougher.
