Hello all, if anyone has followed any of my posts you know that this $500 focus has had A LOT of problems. I'm in the home stretch now, all overheating, drivability, and steering, suspension problems are fixed. A little while ago I broke a shift cable driving in downtown and limped it home. I bought new cables and a short shifter from cfm. When swapping to the short shifter I messed up the flower pedal piece that holds the shifter in the base. I have a new base to install everything in and I need the part numbers for the flower pedal piece as well as any other bushings or such that I will need. I know there is at least the one on the other side as the flower pedal. Any and all help is appreciated.
