1 - 5 of 5 Posts
Steve mk1focusst
Whwn i drive my st170 every now and then it looses power. I have no warning lights on the dash. I have changed the spark plugs. Ht leads . Coil pack gave it a service.
I have been told it could be fuel pump. Air leak from the in let manifold. Lamba sencors. Cat. Any ideas please
Steve mk1focusst
Get the Torque app and a obd2 adaptor.
With Torque, you'll be able to watch fuel pressure, fuel trims, timing, etc..
Sent from my SAMSUNG-SGH-I527 using Tapatalk
Check your PCV hose on the back of the engine. If you have stuttering, especially while cruising, this is a common issue. It will slowly get worst until your car won't run at all. It's an easy check and an easy fix.
Steve mk1focusst
I have been told it could be fuel pump. Air leak from the in let manifold. Lamba sencors. Cat. Any ideas please. Visit Autofthings to view the best battery tender that you may concern.
It seems an intake manifold leak (vac) from the seals. These gaskets have been revised from the original. Take a look at this.
1 - 5 of 5 Posts
