Do all of MK1 years use the same front brake rotors and pads? Or, does the 2005-2007 use a different style? Thanks.
Yea the '05+ cars are 10.9'' vs the earlier 10'' cars. The svt's use 11.8'' To upgrade your brakes you'll need the '05 only spindles & the bigger ball joints or '05+ lower a-arms. Then you can add svt front brakes or any BBK you want. Using the '05 only spindles allows you to use the earlier '00-'05 struts. Where ford changed out the strut diam. for the '06+ cars. Ford when to a bigger ball joint in '05.Do all of MK1 years use the same front brake rotors and pads? Or, does the 2005-2007 use a different style? Thanks.
