Did a compression test today #4 cyl. had zero[bigcry] . Is there a test to see iff it is rings or valves without tearing into engine (so I can limp it to shop if its rings).
A very common problem with the SPI is to lose the valve seat in the number 4 cylinder... that is what killed mine and probably 5-6 other peoples focus on this forum. Sad but true, you will likely be either junking your focus or doing an engine swap. Do you have a bore scope? Otherwise you might have to take off the head to see what is going on.
Well I still owe to much to junk it, so I guess I'm taking the head off this weekend. hope it is just the valve not sure I can afford a new engine at this time.
Well it was definantly the valve seat. #4 piston is chewed up bad but no holes. the exhaust valve stuck open. All the other pistons are usable but the head is shot. I guess I'm replacing engine or rebuilding it. I will just replace if I can find one loacally for cheap.
Related Threads
Focus Fanatics Forum
5.8M posts
189.1K members
Since 2003
