01 SPI Sedan 63,000Miles Stock
My father called me up the other day and said his car had no get up and go. So I took it for a drive and there was a very noticable misfire. But if you drove it like a grandma it was fine. But if you gave it half throttle right at about 20mph and on up it would pull 3/4ths of the time, but every second or so it would basically do nothing. Changed the plugs and gapped them properly. 2/4 had no electrodes left. They were the original plugs. Although this didn't help the issue. Sprayed water on the wires and they were sparking in about 5 dif. spots. Changed the wires and put them in the right order. Still doing the same exact thing. I rulled out clogged fuel, because it still lets you get up to 70mph if you do it gradually. I also rulled out timing because it idle fine. ???????????? No codes or anything. What do you think? Should I replace the coil pack? Please give me some ideas.
