I know this has come up before, but I would like to revisit it.
I am getting a misfire during right hand turns IF during the turn, I apply fuel. Example: Summer: There is a sweeping right hand exit ramp that I can take at speed (but slowing down due to engine drag). At the end of the ramp (if traffic is clear), but still turning right. If I apply fuel there will be a moment of 'misfire'. Present: It's cold outside. ~20F. I am stopped at a stop sign. I am turning right into the closest lane and need to accelerate quickly. I begin to move out, turn the wheel right and apply a good amount of pedal. The engine misfires continuously through the turn and does not stop until I have the wheels straightened out, then it goes like a scalded cat. Could this be the rev limiter? While there generally understood to be RPM based, there is a setting "Max load to turn off injectors" which is set to .250. Advantage does not provide an explanation of this setting however. .250 what?. If the right side wheel is the primary driving wheel, this may explain where the misfire is coming from if this scalar limit is being reached.
Thoughts?
Thoughts?
