2004 ZX3 2.3l pzev 85k miles
Description of general symptoms: Idle settles around 750 rpm but then it will get rough after less than a minute, progressively worsening and sometimes as if it's going to stall. I don't wait to see what will happen for fear of making it worse, so I'll either throttle a little or shut it off. When it's worst it will immediately drop into it's stuttering idle when the revs drop, instead of going to a steady idle. And at those times I sense a hesitation when I throttle like I need to give it more than necessary to maintain a higher rpm (1500-2000). Also noticeable putt-putt sound from exhaust around when it starts stuttering. Seems worst after stopping after my commute (just 15 minutes in suburb driving), but honestly tough to determine a particular environment that makes it worse. CEL would turn on occasionally but would go away (*since I had one coil replaced almost year ago, background on that below).
Fault codes: (current) P2195 (Front HO2S Signal Stuck Lean bank1 sensor1)
(pending) P0300 (random/multiple cylinder misfire)
(pending) P0316 (misfire detected at startup)
The pending codes appeared once a few days ago. Have not recurred, even after numerous drives and idling for several minutes while monitoring engine.
When I monitor the engine tests through the Torque App I see some misfires occuring on Cylinders 1, 2, and 4. Between 10-20 on average, and cylinder 3 will occasionally register a misfire as well. These tests usually do not register as FAILS, though I have linked to a test that did which occurred during one of the almost-stalling while idling moments. Also not sure what to look for regarding vacuum readings from live data. Seems to stay around 20 at idle, sometimes lower around 19, even 18. Does not seem to drop dramatically when RPMs dip as it stutters while idling.
LINK TO MY TEST DATA: https://drive.google.com/file/d/0B71DAMgsL-jTcl9XTlVOX292VU0/view?usp=sharing
This leads me to think either:
a) The three older coils are bad (which i get the impression is unlikely from reading forums) OR
b) There is another problem... research on here suggests the PCV Hose (today will take car to dad's garage to put on ramp and get under it to see if I notice any leaks.)
Does it make sense for a lean condition to cause more misfires on older coils than a new coil? If I were to replace all the coils would it mask another problem causing more issues in the future? (As well as wasted $ on new coils). I will try the newer coil in another cylinder today but I suspect it will perform the same. Just had limited time available to work on car recently (this is my one day off)
Would bad coils causing misfires also create a putt-putt effect at the exhaust?
Last week I replaced one plug BOOT (coil on plug). Originally intended to replace all of them after having one coil replaced and doing research online suggesting that the plug BOOTS could make it seem like bad coils (*see below for background). I replaced the boot on cylinder 1. That did not seem to help. Before replacing other plugs boots I got an OBDII reader and the Torque app - NOTE: I am new to this, most of my mechanical experience came from working on an '83 VW Rabbit and an '82 Honda motorcycle, and otherwise doing routine maintenance on other, newer, vehicles (oil changes, brakes).
If somebody could look through my OBD test data (link above) and see the significance of other FAIL tests that would be greatly appreciated. Or suggest other items I should look for using the tool. I did hours of research online and am afraid I am confusing what is significant and what is normal. (Reading through: http://www.motorcraftservice.com/vdirs/diagnostics/pdf/OBDSM407.pdf has been of limited help given I am a novice).
I will updated with what I learn today after poking around under car and testing new coil in a dif cylinder.
Thanks so much for any help!
Alex
*BACKGROUND on previous coil issue. Had a bad coil last January. Started car up, drove down driveway. Noticed stuttering, hesitation on acceleration, almost stalling from idle. CEL blinking. Put car back in driveway, got mechanic from shop down the street to come by with a computer. He pulled plugs on coils while car was running and was clear one coil didn't make a difference un-plugged. So that was easy and they replaced it. Another coil may have had issues but they weren't sure and I opted not to replace all of them (believe it was cylinder 1). They replaced all spark plugs too.
Edited: to clarify I was referring to plug boots not sparkplugs.
Alex
