1 - 5 of 5 Posts
Hi can anyone help out with a misfire on a ZX5 .... 2.0 l ...ztec .... automatic, only happens on acceleration around the 60 - 80 kms range most times it's just 3 or 4 quick little misfires then it's fine .... wires and plugs changed less than a year ago. 154000 kms on car. No check engine light, Any ideas ? Oxygen sensor maybe ? Thanks for any info.
Oh yes it's a automatic and I didn't hook up the scanner because the check engine light is not on. Could there be a code without engine light on ? Thanks...
Moved to General Tech Chat.
Could have a "pending" code, won't light the CEL unless the situation repeats for a while.
Usual advice is to look at the coil pack for any signs of cracking, that can let moisture in & the coil deteriorates. Misfires often noticed first at higher loads.
This....
1 - 5 of 5 Posts
