yes, mine works..Can you cantrol the rear defroster by voice with MFT in the Focus?
I didn't see that one. Thanks for linking the threads.See here for more info/attempts with regard to this:
http://www.focusfanatics.com/forum/showthread.php?t=269006&highlight=defrost+voice
Hmmm, interesting. It never works for me, even after I installed the insulation around the microphone. Are you sure it turned on the rear defrost (button below climate contol has the yellow light illuminated)? I ask only because I have tried many times and occasionally it will respond with "Defrost Panel On", but that's not the rear window; it's the front defrost and the dash vents.yes, mine works..
i'd say "Climate" first then say "Rear Defrost On/Off".. sometimes it does not get it the first time though
Same here. Mine can't be controlled by voice nor is it listed in the menu.Because it is not listed in the "what can I say screen"...
