Has anyone here ever put a megasquirt ECU on an SPI?
[thankyou]
[thankyou]
^ Best betAgain why when you can get full control of the stock ECU with the SCT ProRacer package or get a tune from me with free tune updates as you add more NA mods
But its a SPI lolthere are several reasons you might want to megasquirt.
Laptop tuning and monitoring and display.
Open end modification.
The ability to add any displays or gauge screens.
The fun of learning how the system works(education)
Bad OEM ECM
Etc Etc...
Yes if you can do tunes on the OEM and set up a screen to monitor all inputs and outputs you want then there would be no reason to switch.
Depends on the amount of control and amount of "tinkering" you really wanna do.
I will admit I have very limited use of hand tuners. The only one I've used it a Diablo on my mustang, but you still have to have a custom tune sent to you or fiddle with it off line. You have no way to hook a direct display up in the car.
I may be wrong on this since I have no to basic knowlege of hand tuners.
Yes the diablosport predator will do monitoring and display of all sensors on your Mustangthere are several reasons you might want to megasquirt.
Bad OEM ECM
Etc Etc...
I'll admit I am a newbie to what can be done with the SCT line up tuners but just looking at the webpage all the above can be achived depending on which programmer you choose. Feel free to correct me anyonethere are several reasons you might want to megasquirt.
Having a setup screen and monitors looks like the hand held ones can offer that too. The only bulky part was the laptop in the passenger seat. ( yes I rejoiced when MSDroid was released [pray])Yes if you can do tunes on the OEM and set up a screen to monitor all inputs and outputs you want then there would be no reason to switch.
Maybe not as standard, but it is available: Megasquirt Knock Module.no knock sensor
^^^^^^^This [thumb]If you've never done any previous tuning, MS is not for you.
TBH, no matter what version you buy, even the EEC-IV of the mid 80's is more powerful. MS is very limited in what it can do. Basic fuel and spark is about all you'll get. Things like EVAP, EGR, etc are difficult for it. It can do them, but not nearly as well as any stock ECU.
And yes. IIRC Jeff was on MS with his turbo car --> http://www.focusfanatics.com/forum/showthread.php?t=84581
