1 - 15 of 15 Posts
Retired Focus Addict
I want to get the crane stage two cams but the valve springs but it says to specify the duration and lift while ordering... when do I specify???? I almost complete my order and not once did it ask me to put what duration??? What do I do about that... sorry if this a complete idiotic question, and sorry if if this is in the wrong forum...
Discussion Starter · #4 ·
I am actually going with the cosoworth cams that don't require the valve springs so and the SCT XCA2...
Fl3tch...LOL
Discussion Starter · #6 ·
well cause I want to go with the cams that don't require upgraded valve springs and those would be crane stage 1's or the cossie ones and if you look they are basically both the same duration and lift, they may be just made of different materials but I since they are both the same I am leaning towards Cosworth because I just trust their products, I mean should I be going with crane stage 1's???
Livin' it up in Cali
the crane 1s are a little more agressive than the cosworth cams........... Id suggest getting the cranes, but that's jus' me.
I'll go look, but offhand I seem to remember that the Crane's had longer duration. It's been a while since I looked at the Cossie cams.
You already ordered the cams... so what's the point in discussion?
1 - 15 of 15 Posts
