Hi!
Ive been driving a good 20k on my new Ford Focus 2014 SE w/ Manual Transmission.
Now, ive been having an issue shifting gears. I came from an old VW 97 Jetta, which ppl told me allows for more clutch slippage, so I figured I would give some time before I complain about tranny issues.
But here is my issue, that I cant seem to perfectly solve. It happens even more when i have passengers in my car, or on a hot day too.
Essentially, when I try to shift from N to 1, or 1 to 2, and sometimes from 2 to 3, it feels as if the clutch engages (and sometimes disengages) way to hard, and its virtually impossible to get a smooth shift through the lower gears.
This is most pronounced when I am going from N to 1, where if I do not keep the rpms balanced at exactly 2000rpm as I release the clutch and give gas, I can feel the gear engage very hard... Its interesting because my car will already move and seems like its in gear as I start easing off the clutch and giving it gas, but if its higher than 2000 (or lower), it seems like there is a point where the gear engages very hard, then the rpms shoot up much faster than before... I then get similar issues as I shift through the lower gears, whith some relatively jerky shifts from time to time. Its become virtually impossible for me to shift through the lower gears without some jerkiness...
Is this a real issue, or do I still really need to learn standard clutches better? Ive been driving standard for quite a while.... The problem also seems more pronounced on warm weather days....
