1 - 2 of 2 Posts
Hey all, I have a 2003 zx3 with a zetec. I did the manual swap out of a 02 zx3 with a zetec. The only issue I have now is that my speedo us inop. I know you can rewire the 3 wire to a two wire. Does anyone have the directions or knows were i can find it?
Most likely you do not have the VSS connected. VSS needs connections to power (F9 via power hold relay), ground, and signal to PCM:
https://forums.focaljet.com/showthread.php/518685-auto-to-manual-swap-wiring-how-to
Good luck
Paul
1 - 2 of 2 Posts
