Put a Spec clutch setup in an '03 SVT focus including a new slave cyl provided with the clutch from Spec.I have NO pedal resistance,I have bled it like brakes,let if "bled with the bleed screw cracked for several minutes,used a handheld vacuum pump to try and pull fluid/air out,even sealed the master cyl resivoir and pulled a vacuum on it as well,no dice It's almost like the clutch isn't there and YES I have made sure the rsivoir has plenty of fluid each time.I really need some educated /experienced suggestions here THANKS guys!
