1 - 6 of 6 Posts
i made an homemade intake but the maf is cutting my engine at 2500-3500 rpms anyone know why????anythang else i should do
Focused Focus
Well, without seeing it, id say you probably have the maf tube the wrong diameter. You are talking about making your own cai, right? If you made your own cai, you have to keep the diameter of the tube, at the maf sensor, the same diameter. If you dont, the calibration with be off, even 2mm can screw it up. The only way to correct that is with a tuner or change the diameter of the tube back to the stock size.
Focused Focus
Hard to tell then, needs to be put on the computer and checked out.
1 - 6 of 6 Posts
