My SVT has trouble starting when it has been sitting for a long time, and runs bad at idle for like 2 min or until I go and reach like 3000 rpm. If I just started it and I give it some gas, sometimes the rpms even drop and it wants to die... When the problem began around 1 month ago I removed the MAF and cleaned it with contact cleaner, seemed to help a little at first but finally it didn't solve anything. I also unpluggued and repluggued all the sensors I could in the engine bay. Thinking it's probably a clogged fuel filter, I bought a new one and will install it today.
I did some datalogging with my Predator this morning and the fuel rail pressure is stable at 40 psi, so I doubt the fuel filter will improve anything. The MAF reads around 0.8V at idle (950 rpm), is that what it should be reading? What else can I look for?
