1 - 14 of 14 Posts
· Registered
quick question. I am building my own intake for my 07 2.0 duratech.I am wanting to change all the plumbing to 3'' but i am wondering, will that screw up the MAF readings. Should i just leave the MAF tube as is or will i be ok incorperating the sensor into a 3'' tube. thanks for the help in advance.
· Registered
keep the stock MAF tube... if you put the maf inside a larger INside diameter tube than stock, it'll run lean, because the MAF doesnt see the extra air thats passing it.
· Registered
A 3" intake is your best option but the car will needed to be retuned after to get the maf reading the correct amount of air. We are working on this right now and should be going to the dyno with in the next couple of weeks to check on our progress.
We do have 3" maf tubes in stock for the duratec right now if would like to go the route mentioned above. Click the link below to check them out.
HTPerformance.net
· BodyKits=PantiesDrop
^^even if you buy that tube it will need to be tuned to work properly
when i made my own custom CAI i kept the stock MAF tube, you will have to as well
· Force-Powered Focus
u need to keep the stock maf tue, or get it retuned. thats all there is to it. u can buy whatever tube u want, but it needs to be tuned for that, or u will not run right.
· Registered
my intake from hps is 3inch but keeps the stock maf housing if not would be to much air passing through and you would need a tune becuase the car would not know what to do with the extra air
also ? for the mechnically intelligent people lol
i installed the hps intake and now i noticed that when i hit the gas fast sound like a little whistle for a split second of what sound to be air like only when i step on it or press the gas faster than usual also i got a check engine light now i think the air sensor moved or something what can this be car runs great
make sure u unplug the battery to reset the ecu, but also, that whistle is normal. i dont know y u have a cel tho.
· Registered
yea mine whistles also. I'm pretty sure this is normal, and to be honest I really prefer it.
Lol as a side note hatches.....periods and punctuation help a TON[limp]
· Registered
lol i like the whistle like a turbo lol but yeah i didnt reset the batteryn so ill do that for and let you knoe thanks agian to all of those who help
doesn't the cosworth cai use a bigger tube? how's that work?
there is an insert...just looks bigger on the outside. f2 tried to do a cai with a diff maf size....it failed, had to kill it, went back to old design
1 - 14 of 14 Posts
