Hi everybody.
First post so wish me luck...!
I have a european Focus 2004 Zetec SE 1.4L MK1.5 (facelift).
I would like to know if my car has a MAF sensor. According to Ford's manual it should be like this :
But my engine looks like this :
And not like the Zetec photo in this thread which is similar to the first diagram
http://www.focusfanatics.com/forum/showthread.php?t=337457
So does anyone know if there is a MAF sensor somewhere else? Or does it have a T-MAP sensor instead?
The reason i am trying to find it is because i am having rough idle problems and bad acceleration/throttle response.
To elaborate on the acceleration problem :
Sometimes, mostly when climbing hills, i have no acceleration response, no matter how much i push the gas pedal. In order to regain control, i lift my foot of the gas pedal and hit it again. Then it feels like responding again. But not quite as good as it used to...
I have replaced the IAC valve and also installed a new clutch set already...
I also checked multiple times for vacuum leaks. Found a broken pipe once and replaced it.
I am trying to figure out the problem myself because both solutions proposed by the engineers, did not address any of my problems.
So i am thinking of checking the MAF or MAP sensor and the TP sensor also.
Thanks in advance!
Thanks in advance!
