I made a new antenna at work today. I make so many parts for other people, sometimes I need to "test" my skills on "sample" parts. I decided to keep it simple. .54 at the base, 1 inch of straight shaft, then it tapers down to .4 at the end, it is 5 inches long. Made it out of aluminum and it took me about an hour. I used a cnc lathe to turn it down and cut it off, then I used a coax center finder to find the center with a bridgeport manual mill. Then I drilled with 5mm and tapped 6mmx1 using the bridgeport. I'll probably make a few extras in case someone tries to steal it since its already programmed on the lathe. How long do you think before it breaks off my whole antenna mount in a car wash? There's not that much give to it.
