Mach Radio replacement
1130 10
I have a Mach Radio just died found a replacement what is the correct procedure.thx
1 - 11 of 11 Posts
Vince your Moderator
Please be more specific with your question.
I installed an aftermarket deck into a Mach system once. It was a nightmare.
I'll get this moved to a better section.
Discussion Starter · #4 ·
Mach radio
MyMach died and I have a replacement the exact unit. Are there any codes or just unplug neg from battery and pull old unit out unplug then plug in new oem re install connect neg battery and turn on unit??
^Yes
Dat boxer rumble
YES there is a CODE or NO there is No CODE Just follow install procedure?
There is a code, but you will need to join the elite organization of those who read my previous post.
^once again, yes.
1 - 11 of 11 Posts
