1 - 5 of 5 Posts
Well I just got out of work and since it gets dark by the time I get out... I went to turn on my headlights and guess what they didn't work. parking, turns and hi's work, but no low beams. When I would hold the hi's on the low beams came on but when I let the stalk go they would turn off as well. They don't want to stay on. What could it be?
The stalk is called the multifunction switch. That's what you need. Very cheap online, the dealership will rape you. Check with vendors on here and save alot of money.
Discussion Starter · #4 ·
This is exactly what the problem was. Thanks bro and I gave you some rep[pray]
You're welcome, I've seen this problem before. When you said the lights still worked, I knew it wasn't the fuse.
1 - 5 of 5 Posts
