1 - 4 of 4 Posts
I have a o7 focus and I want to install the mach sub with the two mach amps I need to know the wiring for the amps there are 10 pins and I have been all over the net looking for this info and no luck any help would be great thanks[mecry]
What sort of wiring info do you need? The factory wiring is just going to have a huge plastic connector of some sort to attach to those pins....are you retrofitting this into a car without the Mach system?
Yes I am putting the mach sub in a 07 focus that has the 6 stack cd changer I know that the 2 red and white are the feed for the amp dont know which is - and which is the +
My guess is red is positive, but I don't know for sure. You can try testing the wires with a test light or voltmeter...whichever one has power will be the positive.
1 - 4 of 4 Posts
