1 - 6 of 6 Posts
Will this damper kit work with my STOCK 2007 SES 5 door front and rear springs? Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
Correct, you need the 5560-zx3b if you want to use the FRPP set. They don't make it anymore, but you can still find it places.
All the Ford sites show that the zx3b IS for the 06 and 07 cars. My question is will it work with my stock 2007 SES springs.
I think you can install them with your stock dampers, but I wouldn't advise it. Those dampers are designed to be used with a lowering spring, so use with stock shocks may decrease the life of the dampers
Sorry, misread when I went to confirm which was which - posted the link in my original reply as a correction.
They'll work, but regular replacements might work better. Damping is set for a stiffer set of springs.
1 - 6 of 6 Posts
