1 - 9 of 9 Posts
The damper kit won't change ride height by itself, the change is made just by the springs when using that kit for the designed drop.
OK - so I can use this with the stock springs? This seems like a great deal on 4 dampers and the strut mounts but I want to keep my car at the current height. Thanks.
Yes you will be able to use your stock springs. That is how the 07 st came from the factory.
But I'll also add that you wouldn't regret dropping the 1.5 inches ?
Thanks! The person using the car has a physical need to probably keep the height as is. If we did want to lower it what would be good springs for those dampers?
So mote be it
looks like those are no longer available
Im sure there are still several sets floating around but you are right, no longer available new from Ford. Ebay or the bst section here (such as my link from earlier)
Normally we call this setup the FRPP around here, was a great budget setup. I'd always recommend it over just replacing parts with oem stuff...couldnt beat the performance/price ratio. I enjoyed my set while i had it, good for daily use
1 - 9 of 9 Posts
