1 - 5 of 5 Posts
I was looking around on the forums and couldn't find a similar thread to this question. Unsure if this is the right place to post this either haha.
307056
Just installed a clutch kit from Luk including the throw out bearing/slave cylinder, pressure plate and clutch disk. Everything is back together but I'm having an issue getting my clutch pedal back. I used a vacuum bleeder on the slave cylinder but was unable to get fluid to come out if the bleeder valve when depressing the clutch. The LuK kit came with a little line adapter inside of the slave cylinder but was wondering if it has anything to do with my lack of pressure in the clutch. Pictures will be attached. Thanks in advance for the help.
The fitting was originally in the LuK supplies slave cylinder but with them I was unable to attach the line with it in. I took it out and connected the line but I'm still unable to get pressure in the clutch pedal. Any help is greatly appreciated.
307058
Did you fully open the bleeder valve?
Paul
1 - 5 of 5 Posts
