Is it worth time and money for LSD at the dragstrip. What are pros and cons of the diffferent brands? Opinions on which brand to get for drag applications. Just on an information hunt before i go spending money.
this guy is spot on, i can take some pics of my broken diff from when i launched on just some drag radials making around 220whpIf you are serious about drag racing a limited slip is just about mandatory.
Pretty much the same, and there is a write up somewhere also a video on youtube. ill look for youany difference in the torsen and quaiffe? quality experiences. planning on doing clutch flywheel and everything so figure while i was doing that might as well get the lsd. another question. thinking about doing the lsd install myself. anyone know of a good write up on doing the lsd.
i had that same problem with my stock zetec but with 225/50r16 traction T/A and a bad 5K RPM launch. One of the planetary gears just opened in half. That convinced me of being careful with my launches and getting an lsd but when that happened i had no money so i found a used diff. for about 80$ .this guy is spot on, i can take some pics of my broken diff from when i launched on just some drag radials making around 220whp
I 2nd that! Try slick's 1st. You are going to need them anyway.Here's a good way to tell if you need a lsd. If you are having traction probs with slicks at the track get a lsd.
