1 - 14 of 14 Posts
I Just finished installing my JRSC on my 2000 zx3 and I am only getting 3 pounds of boost, I have checked everything on the system and can not find anything wrong. I was wondering if anyone else has had a low boost issue with there JRSC or if Maybe mine is bad..
Haven't thought of that one. Will check that out. Thanks for the idea if you have anymore let me know
I have started the car and took carb cleaner and sprayed it all over the engine looking for a vacuum leak and I cannot find one so I am going to say that I don't have one.
on thin air
Check the nipples on the back of the manifold as well. They have been known to vet loose and leak...jb weld fixes that.
Sent from my MB855 using Tapatalk
MOAR BEWST!!!!
bad wastegate?
A wastegate on a supercharger...not so much.
on thin air
but there is a by pass valve. that has been known to get holes in the diaphragm. that could be Worth checking out as well.
Yes. A faulty bypass valve is a common culprit.
Discussion Starter #11
Well I hooked up my vacuum pump to it and I could get it to open and close. I think its still good but does anyone know where to get a new one or a rebuild kit for It ?
My friend had a Mini Cooper S that wasn't holding boost. Turned out the HOSE to the bypass valve had a sizeable tear in it. So I would look around for tears in hoses.
Discussion Starter #14
i will check all this out. thanks for the help guys i know that someday i will figure it out and have a boosted focus...
1 - 14 of 14 Posts
