Hey all, I've searched on the forums but couldn't get a definately answer on some things:
I just installed the focus central 60mm TB on my SPI and the bracket from my SPI for the throttle cable didn't fit. Are we meant to use one from a zetec or anything special?? I'm looking at getting another SPI bracket and modifying it, as now mine sits rather badly until I sort this out.
2. I also got given a RACTEK intake for free to compliment the 60mm, it had a maf sensor on it but as soon as I installed it threw a CEL. so I have put my MAF from my SPI on there (same same AFAIK) and it's still there. One thing to add is the maf is directly behind the pod filter which I thought was a big no no but that's now it fits?
3. My TB came with a new OEM TPS which I installed the same as the other one but I notice my idle doesn't drop down as much as it used to with the car feeling like it's "running on" when gearing down. I gave it a wiggle and even moved the idle screw with no luck. My incling is that the MAF or the CEL might be behind this a bit (such as my idle being now 1,000rpm) but the running on in gears to me would be the TPS.
4. The idle as mentioned in point 3 is now 200rpm higher.
I have checked and rechecked the TB For leaks, all hoses tight, new gasket etc but to no avail. Any information, suggestions or ideas is welcomed. I have also disconnected the neg, and relearned 3 times with no luck
