1 - 5 of 5 Posts
Hi,
I received my SVT Procharger kit(purchased it from McNews) and had some questions about it that maybe you can answer. My pulley is stamped w/2.67 on one side. There is some conflicting info on this forum as to whether this is the 8lb. pulley or the 10lb. pulley. Some say the 2.55 is the 10lb. pulley. This conflicting info actually came from ATI!!! Can you clear this up?? I'd really like to know before I begin the install. Can you also confirm that the 2.25 is the 15lb. pulley?? If I have the wrong one, I'm just going to go ahead and get this one.
Did you get an e mail back. I had seen you sent one to the shop.
If you're referring to the one about the pulley size, yes. Thanks
You have the 10 lb. The 2.25 should be 15. Boost is dependent on backpressure in the intake system based on the efficiency of the setup.
Understood. I was just trying figure out which one was "advertised" for 10lbs. on a stock car.
Can you shoot me a pm or email with a price for a 2.25" pulley, shipped to 33323??
Thanks, again.
1 - 5 of 5 Posts
