1 - 20 of 34 Posts
Lot of SVT Parts SVT Header/Cat, SVT Cluster & Other Parts from a Parted Out 03 SVT
I have a bunch of SVT parts of a 03 focus svt. Prices plus s/h
1). Getrag SVT 6 Speed Trans- Pulled around 100k when original motor blew $400
2). SVT Intake Manifold Upper/Lower Pieces $125
3). SVT Header, No bracket/headshield $125 (No bolts)
4). SVT Flex Pipe $50 (No bolts)
5). SVT Cat $75 (No bolts)
6). SVT Computer with Key and tumbler $125
7). SVT Engine Head Pulled from Motor with lower end noise, Needs some clean up $250
8). SVT Gauge cluster w/ add on gauges $125
9). SVT Front/Rear Red Door Panels $150
10). SVT Front Pass Seat w/ Heater- Missing handle $125
11). SVT Sunroof Assembly worked fine $150
12). SVT shift knob kind of scuffed $25
13). SVT Axles Needs boots replaced $50 pair
14). SVT Spare tire $50
15). Coil Pack/Plugs Missing 1 mounting spot $15
16). Bare SVT Block w/ Head bent valves $100
17). Power Steering Pump $35
18). AC Compressor $50
19). SVT Oil Cooler assembly $75
20). Alt $35
All parts are or best offer
I'll add more as I go through the stuff.
Please contact Eric D via PM
OPEN TO OFFERS!
ninja lurker status
gawd!
i want that focus central tb... but i shouldn't be spending money right now..
I'm interested in the focus central tb. What diameter is it? And what application did you use it for? Turbo? Supercharger?
Discussion Starter #19
Sorry was out of state for a few days. The aluminum Throttle body I believe is 65mm, I got it used off a turbo svt focus, the oil pickup is that under the oil pan I assume? I have heated seat switches but those are going with the center console. Ygpm back for stock Tb. I still have the ac compressor.
1 - 20 of 34 Posts
