Just bought this 2002 ZX3 and am having electrical problems. Any help with would be appreciated.
Lights
Low beam lights rarely work. High beams always work. When I pull back on handle both low and high lights turn on as they should, but upon release the lights turn off if switching to low beam. Every once in a while they work. I tried switching the relays around, then put in some from a junkyard car, and nothing changes. Could the problem be in the multifunction switch?
Sunroof
Only the open switch works. Pressing the close side of the switch does nothing. But if you keep holding the open switch, the sunroof opens all the way then closes all the way. It doesn't stop at the end, just reverses directions.
Stereo
6006 model stereo. Volume doesn't work right. If I try to turn it up, sometimes it goes down, sometimes up, sometimes up then down. Same when I try to turn it down. I decided to get another 6006 from the junkyard, and it does the same thing. Is this a common problem with these radios, or is it in the wiring somehow?
Lights
Sunroof
Stereo
