1 - 4 of 4 Posts
Hello everyone! I'm having a few lighting issues with my 2006 Ford Focus and was wondering if anyone had any advice?
1. My passenger side headlight doesn't produce a low beam. It will produce a high beam, just not a low beam. I have so far switched out the bulb and also checked the fuses and so far nothing. I'm thinking about switching the driver headlight and passenger headlight relay to see if that does anything but worried that I might screw something up.
Any advice on what's the best option here? Should I take it to a shop?
2. The light that lights up my gear shift in the center console went out awhile ago and I would like to replace it but I'm not exactly sure how to do that. Do I have to remove the center console to replace it? Any advice here would be awesome too!
Thank you,
Toby
Welcome to FF
Moved this to General Tech Chat, that's the best place for repair questions & looking up threads with prev. answers.
Are you sure you checked the right fuses?... Because the passenger side Low beam has its' own fuse. The whole headlight system has 5 fuses.
1 - 4 of 4 Posts
