I had my radio bezel off today for painting....easy enough. But while I was at it, I decided to upgrade the OEM lighter socket. I don't smoke, so I prefer to have a standard 12V outlet. Sounds easy enough, and I had a few extra sockets laying around.
What a P.O.S. job. The stock socket is a bear to remove, and once I had it removed, the hole was much bigger than the sockets I had. So off to the parts store.....bought a lighted socket assy, just to get the amber bezel. I had to cut up the stock lighter to use it's outer black bezel also (hard to see).
Then since I couldn't use the lighted socket (it was the lighter type) I had to use a standard socket. But it wouldn't install with it's own back section, which was too long to use with the amber bezel. So.....I had to use a back piece from a third socket.
Then the entire assy wouldn't tighten down correctly.....so the whole thing had to be glued together.
And the Ford harness plug of course was different... so I had to make new connectors.
Last......the little light for the bezel of course wouldn't fit the modded socket. So I had to cut up a fourth socket I had and mod it's holder to fit, not to mention I had to make a new wire harness for the thing.
In all.....painful. Do it at your own risk. [rolleyes]
