1 - 2 of 2 Posts
Can someone help me? I believe that I have a light - it is attached to the battery, under the hood on my 2008 Focus SES. It does not come on and no reference is aparent in the instruction book. How does it turn on?
Thanks,
Focus Hoarder
the majority of the time it uses a tilt sensor tilt the housing horizontal turns the light off tip it vertical it turns it on.. Im unsure about the 08's tho :( all I have are 01's hopefully someone can help you with this.. My car did not have one originally but I installed one from my old Gutted Beretta which all i did was clip it to the reinforcement area (the metal clip is the ground) then run a single positive wire to the battery, it turns on when the hood is tilted about 20 degrees up
1 - 2 of 2 Posts
