very easy fix. Get some 3000 grit (or higher) sandpaper. Put a small amount of water on the area thats scratched and wet sand it until the scratch blends in. Go slow and wipe often. This will "scuff" the clear coat, and look really bad. Don't worry. You will need some buffing type wax. We use a product made by 3M called finesse-it at the plants. 3M also makes a scratch repair kit you can find here
http://www.amazon.com/3M-39071-Scratch-Removal-System/dp/B003NS5NK8. It comes with a buffing wax I believe. Anyways, after you wet sand the scratch out, you use the polish to remove the scratches from the sandpaper, and it will look brand new. This will only work for surface scratches. If it is through the paint, you can use this same technique, but a little different process. Look on your driver door at the label for the paint code, and order a bottle of touch up paint. Do not break the seal for the ball point pen applicator, as it will dry out after you use it. Instead, pour a small amount of paint on a piece of paper or something and dip the pen in it. Now apply the paint to the scratch and let it dry. After it dries completely, wetsand the paint until it blends with the paint, and buff out those scratches the same way.
