1 - 4 of 4 Posts
Hello.I had this problem since I bought the car(second-hand Hatchback from 2006). Even tough my lights are set to the "off" position, the low beams are still on.
Things i checked:
  • fuses
  • relays ( i don't know if i checked the right one)
  • replaced the lights block with a new one
Any ideas or what i should check next before going to a mechanic?
Thanks!
If you do not want the DRLs to function simply remove the DRL relay. Although you seem to have a Euro MK2 and the info in the link above is for NA MK1s.
Good luck
Paul
Yea you were both right.They were DRLs. I couldn't pull out the relay because it's stuck but I pulled out the fuse for it.Now the light are off and only the parking light are on.Is there a fuse for that also? :D
I'll leave them like this if not.
Thank you for the help!
1 - 4 of 4 Posts
