Anyone else gotten this?
This statement is flat out irresponsible and places people in danger:Got the same letter. While it's nice that Ford has extended the warranty, it's not so nice that Ford is content to let us run around with high-failure-rate parts that can strand owners with no warning.
I guess this is one of those situations that until it happens to you and places your family in danger that you really can't know just how dangerous this is.Sorry for the Rant, I've just seen many posts lately on ALL models mentioning avoidable hazards that mechanical failures can exacerbate. Cases where the machine didn't create the situation, it just failed to remove someone from a hazardous one.
Putting aside the safety issue for the time being, how about owner convenience? Like many, we use our Focus for long-distance vacation travel. So now we know the risk of being stranded in Nowhere, Wyoming while on vacation is higher than we had suspected. And there's no way of predicting or preventing this failure. And Ford knows what the problem is. And it's a higher risk of failure than for a 2014/15 Focus. And typically, failure rates of modern, non-Focus TCMs is so close to zero it can barely be measured.Separate comment.
If you recall & replace ALL the existing functional TCM's, it's a sure bet that some of those will fail - and the existing one may not have failed.
The only 100% sure way to avoid a high probability of danger from a malfunction is to avoid a situation where a malfunction would be unusually hazardous.
Current brake systems typically fail to a partial performance mode, so making a habit of driving in a manner that requires full performance MAY someday result in an accident. The most common versions of this don't even require a brake failure, just something like less traction than anticipated or another vehicle that changes speed unexpectedly.
Loss of power can have many causes, the transmission is only one of them. Making a habit of requiring power to avoid a collision MAY result in an avoidable accident. Most common is pulling across or into traffic without leaving enough room for traffic to avoid your vehicle IF it doesn't respond as anticipated. Misjudgement in these situations WITH a fully operational vehicle is the largest cause of serious accidents, so the situation should be avoided in any case.
I don't want to discount the seriousness of an unusually large rate of failures, but since failures of this type WILL happen (no matter how high or low the rate) it makes sense NOT to make a habit of creating situations where the result could be tragic.
Even walking across traffic needs to be done with adequate clearance for safety, running across where a slip or trip would be tragic too often ends that way with NO machinery failures involved.
You act as if every Focus' transmission is at risk of spontaneously disengaging, where are you getting this data from? Do you have a spreadsheet from Ford stating that this many ppl out of this many have had their transmission spontaneously disengage while driving? This is the issue, there is no "defect" being called out in the TCM, the warranty is simply being extended on it, if Ford came out and said "Hey, we found a defect with the TCM that requires it to be replaced" then I hope they would issue a recall and a notice saying "don't drive the car until fixed, here's a loaner." The vast majority of transmission issues on this site are related to clutches, seals, programming, or any combination of those 3 at once, TCM issues, while relevant, account for a small percentage of issues discussed on these forums.I guess this is one of those situations that until it happens to you and places your family in danger that you really can't know just how dangerous this is.
As I said, Ford would not be sending out these letters unless there was a significant risk of failure. This is a CYA attempt by Ford but if someone ends up getting killed because their car's transmission disengages in front of an oncoming Kenworth, then Ford will have a Toyota situation on their hands.
I am personally tired of seeing posts that think Ford is being benevolent about these matters. They are a publicly traded company that must answer to shareholders and cut costs in any way they can.
Regarding your comment about allowing reasonable clearance for safety: I agree and am very cautious but explain to me how you can plan ahead when you pull out in an intersection and your transmission decides to spontaneously disengage. How is that an avoidable hazard?
Ford is basically saying that the TCM doesn't meet its own reliability standards - otherwise no warranty extension would be needed. We have no way of knowing what the failure % is, but as others have said, it must be significant for Ford to even raise the issue. I agree if the failure rate is minuscule, Ford has done a nice thing. But if that's not the case, Ford is happily putting a good percentage of us in the position where we will have a breakdown at the time and place of the car's choosing.You act as if every Focus' transmission is at risk of spontaneously disengaging, where are you getting this data from? Do you have a spreadsheet from Ford stating that this many ppl out of this many have had their transmission spontaneously disengage while driving? This is the issue, there is no "defect" being called out in the TCM, the warranty is simply being extended on it, if Ford came out and said "Hey, we found a defect with the TCM that requires it to be replaced" then I hope they would issue a recall and a notice saying "don't drive the car until fixed, here's a loaner." The vast majority of transmission issues on this site are related to clutches, seals, programming, or any combination of those 3 at once, TCM issues, while relevant, account for a small percentage of issues discussed on these forums.
With your logic, Honda should recall all torque converters on their Civics because they are at risk of failing at some indeterminate point in the future, Volkswagon should recall all Passats because their drive-by-wire throttle might stop responding at some point in the future. It just doesn't pass the logic test, no company can guarantee no issues with their product.
- Or they are saying, hey we want to put customers minds at ease regarding our transmissions, here is a gesture of goodwill. You are assuming.Ford is basically saying that the TCM doesn't meet its own reliability standards - otherwise no warranty extension would be needed.
- If Ford were ever to be caught "happily" putting it's owners in a dangerous situation I would be the first to jump on the anti-Ford bandwagon. I choose to believe that in this day and age they would be smarter than that, especially after what they just saw their cross-town rivals go through in the courts for ignition switch recalls (GM.)We have no way of knowing what the failure % is, but as others have said, it must be significant for Ford to even raise the issue. I agree if the failure rate is minuscule, Ford has done a nice thing. But if that's not the case, Ford is happily putting a good percentage of us in the position where we will have a breakdown at the time and place of the car's choosing.
- Listen, I'm right there with you on the resale values, it sucks that my '12 has a crap resale value, and I'm sure people going online and searching Ford Focus problems and finding this forum has a lot to do with that. Again, I am not going to assume Ford is choosing to hang an unresolved issue over our head, but rather trying to rebuild consumer confidence in their product.I don't know what a TCM replacement costs Ford, but I would bet it's modest, certainly compared to a torque converter on a Civic. And keep in mind 2012 Focus DCT owners have been put through lots already with multiple trips for reprogramming, lots of clutch and seal replacements, trashed resale value, etc. Ford hanging this unresolved issue on top of everything else is just kind of insulting.
You just relegated your comments to the theatre of the absurd.it sucks that my '12 has a crap resale value, and I'm sure people going online and searching Ford Focus problems and finding this forum has a lot to do with that.
They do their research, read reviews, read forums... and then this happens:Wavsine,
Is it absurd to think that someone who had their heart set on a used Focus would in this day and age, choose to do some research on the Internet for problems, find this forum along with many negative posts about the Focus they were planning on buying, then tuck trail and run?
