Oh wow! Nothing that fancy at all! Haha. I had an old Thule wind fairing that I had found in a junk yard. So I cut that up and then screwed them into the styrofoam bumper.
Thanks! Recently just sold them to Focus On Me, here on the forums. It matches his CF hood much better, and he actually has usable headlights now.
I finally got my retrofitted headlights back, and I love them.
Here's my car and Joe's (Focus On Me) on a quick Taco Bell run.
I need your guys help is the xb led the same as the trs led? I have all new brackets and the lights but the brackets on the lights wont even come close to lining up....
So I’m going to have to change the PCM on my 2011 focus to finish off my transmission swap. Can anyone help me identify the PCM that I’m looking for? I don’t know what the number or code would be for a manual PCM. Thank you
Hi all, I have a 2008 Ford Focus SES that is having some problems starting. The vehicle started to intermittently struggle to start with the problem slowly worsening until the vehicle just will not start currently.
The best I can describe it is a stutter when starting that has slowly gotten...
I made a video comparing $20 sway bar end links to ones that were less than $4.
I put the premium ones on my car first and they went to garbage within a year. I have had the cheap ones on there now for several months, and they've been better from day one. Just trying to help some people possibly...
Recently started noticing that 3rd gear grinds upshifting anywhere over 4500 rpm and the grind gets worse the higher up the rpms are. The car does not grind when downshifting into 3rd regardless of how aggressive of a downshift, just when upshifting. Car is a 2011 with 62k miles. I changed the...
I replaced my passenger side mount with an official Ford part about a year ago, and now it’s shaking again, but only when I have it in drive or reverse. The other two mounts are good. Has anyone seen the Ford mount fail this quickly?
